98 accord ex heater
Old Dec 7, 2010 | 07:45 AM
bozos_si's Avatar
Default 98 accord ex heater
My car barely blows warm air when the car is fully warmed up. does it need a new thermostat? Or what else can be the problem?
Old Dec 7, 2010 | 08:02 AM
With the key ON, check to verifiy the cable actually moves the valve on the heater hose (in the engine compartment). Got a 4-cyl or V-6?
Old Dec 8, 2010 | 11:37 AM
bozos_si's Avatar
yes key was on. I was driving it and the temp gauge was about half way. it is a 4 cylinder. where is the heater hose located in the engine compartment?
Thanks
Old Dec 8, 2010 | 12:26 PM
passenger side of the car. There will be two hoses that go into the firewall. One of the hoses will have a valve that is controlled by a cable.
Old Dec 8, 2010 | 07:48 PM
Please also check the coolant level. If low you might want to bleed the system when filling it. Then denpending on how low it/was or is......find the leak.
And we are assuming the blower is turning at full speed, just no or not hot enough air coming out.
capww8
Jul 18, 2008 07:25 PM
dave0871
Jul 4, 2007 06:38 PM
Pauls95
Feb 7, 2007 06:56 PM
mdjbhouse
Jan 4, 2007 08:33 PM
HankR
Dec 20, 2006 04:00 PM
