04 accord, 02 heater sensor circuit malfunction
Old Dec 19, 2006 | 11:39 AM
HankR
Default 04 accord, 02 heater sensor circuit malfunction
I had a light come on in my wikes 04 accord. It looked like an engine. I put my OBDII scanner on it and it gave me an message that the "02 Heater Sensor Circuit Malfunction, Bank 1/Sensor 2". Can anyone tell me what this means and what may have caused it to come on?
Thanks
Hank
Old Dec 19, 2006 | 01:50 PM
sir_nasty's Avatar
Default RE: 04 accord, 02 heater sensor circuit malfunction
I believe that is your O2 sensor after the cat converter is indicating a failure..... is the car under warranty?
Old Dec 19, 2006 | 03:53 PM
HankR
No, it no longer under warranty. How hard is this to replace? What would cause this sensor to "go off"?(for the lack of better words)
Old Dec 19, 2006 | 08:31 PM
hondadude's Avatar
There is actually a little heater inside the Sensor to get it hot so it can read correctly.
There is no fix other than sensor replacement, before throwing a new sensor at it be sure you have voltage to the heater circuit at the plug.
4cyl? V-6?
Old Dec 20, 2006 | 10:07 AM
ORIGINAL: HankR
No, it no longer under warranty...
'Certain emmissions components' carry a much longer warranty than the 36/36000 overall warranty. Check the warranty booklet to see if the O2 sensors are covered.
Old Dec 20, 2006 | 10:08 AM
HankR
Thanks. It's a 4 cyl. Where do I find this sensor?
Old Dec 20, 2006 | 03:19 PM
hondadude's Avatar
Some states have longer mileage 3/50 warranty vermont maine california are 3I know of
[IMG]local://upfiles/5417/0E2B7B693022484EBA905D12D2B52107.jpg[/IMG]
Old Dec 20, 2006 | 03:27 PM
sir_nasty's Avatar
under the car you'll find the cat (enlarged canister looking thing in the middle of the exhaust pipe) right behind the cat towards the back of the car should be the sensor sticking out, Fairly easy to replace but kind of a spendy little part (around $100.00 I think....) check for power going to it and check out if you have extended emissions coverage....
Old Dec 20, 2006 | 04:00 PM
HankR
Thanks "ALL". I'll check those things and let you all know the outcome.
Thanks again and have a Merry Christmas and a Happy New Year. Stick to those resolutions!
CheriMo0n
Nov 14, 2016 06:14 PM
godey
Jun 25, 2014 03:54 PM
slickgeek
Feb 24, 2014 02:48 PM
smrtgi
Jun 5, 2010 02:25 PM
thisandthatintx
Apr 19, 2007 04:52 PM
