Disc Brake which one is good for Accord
Old Dec 16, 2006 | 03:00 PM
kennilope's Avatar
Default Disc Brake which one is good for Accord
Hi,
I have an Accord EX 94. Needs to change front rotors because it is shaking bad at high speed when braking..
My question is. Should I put in OEM Honda rotors. or should i go with Bembo those slotted drilled rotors?
I had in cheap rotors before and it is not good. My mechanic said Honda Rotor works better... just want to know if aftermarket high performance is better then HONDA.
thank you.
Old Dec 16, 2006 | 04:53 PM
hondadude's Avatar
Default RE: Disc Brake which one is good for Accord
I see no advantage to those other rotors for normal driving; I'd replace rotors with OEM.
if you can find a shop with an "on car brake lathe" you can have the rotors resurfaced.
Old Dec 18, 2006 | 11:17 AM
Brembo makes good rotors, but I don't think they make them slotted or drilled. Most of those 'Brembo' drilled rotors have been drilled by anybody, good or incompetant...
Drilled or slotted rotors don't brake better, they just handle lots of repeated hard braking better. You shouldn't need that unless you do much road racing.
Afteryou replace or resurface your rotors, brake them in like this:
Brake hard from 50 to 10 (don't come to a complete stop). Let them cool by driving for5 or 10minutes. Repeat 10 times. Don't be stupid with traffic conditions while you do this...
Old Dec 20, 2006 | 06:42 PM
kennilope's Avatar
thank you guys.. just put in OEM rotors... dont need drilled or sloated one.....
work like a charms now.......
jrzwalker86
Dec 5, 2011 06:49 PM
Andy2k9
May 15, 2010 05:31 PM
sirgilligan
Dec 22, 2008 10:47 PM
KevinAccord
May 21, 2007 01:59 PM
