Heater circuit O2 sensor on a 97
Old Jun 1, 2010 | 03:33 PM
smrtgi's Avatar
Default Heater circuit O2 sensor on a 97
Can anyone point me towards a guide on how to replace the O2 sensor on the heater circuit of my 97 accord?
I've done some googling without much luck.
Thanks.
Old Jun 1, 2010 | 06:46 PM
corvetteking's Avatar
Unplug the wire from the sensor, find the appropriate socket, unbolt the o2 sensor, bolt in new o2 sensor, plug wire onto new sensor, done.
Old Jun 2, 2010 | 07:06 AM
Have you checked the heater? Find the 2 same-color (black?) wires on the sensor itself. Heater should measure 10 to 40 ohms between them. If that's OK, then your problem is wiring in the car.
Old Jun 4, 2010 | 04:41 PM
smrtgi's Avatar
It's the sensor that's bad. I was able to get it out, but I'm having problems undoing the wiring. The connector just doesn't want to come apart. Any tips?
Old Jun 5, 2010 | 02:25 PM
If you can't get the connector apart, how did you measure the resistance?
There's a latch you have to press, on the side of the plug. Sometimes they get dirty or corroded, & take a fair bit of force to pull apart.
pondrun
Nov 8, 2021 09:40 AM
CheriMo0n
Nov 14, 2016 06:14 PM
godey
Jun 25, 2014 03:54 PM
slickgeek
Feb 24, 2014 02:48 PM
HankR
Dec 20, 2006 04:00 PM
