98 Accord- instrument panel lights and tail lights NOT WORKING
I have a 98 Honda Accord LX. The panel lights do not light up at night after turning the headlights on. I removed the component and replaced ALL the bulbs and still nothing. I bought new fuses and installed them correctly (lol) and the instrument panel still will not light up.
secondly, the tail lights do not come on even after I replaced ALL the bulbs back there. the break lights work fine. not sure what to do next. i checked the connections and they seem fine.
I think that you are going to need a volt meter and a shop manual. I got a shop manual for my TSX from automanualsource.com for $22 and it has all that information about wire colors, etc...
Then you will have to start at a convenient place for electrical testing. I would start at the tail light bulbs that are not working to see if you are missing voltage on the + wire or ground. Then you will have to work backwards to figure out where the circuit is failing.
I have the same problem except my tailights work, to fix the tailights i think mine was a fuse on the passenger side, be sure to check fuses with a test light, sometimes the fuse will be blown but still look ok.
ekg98
Dec 20, 2013 10:20 AM
Jmars152
Jun 10, 2012 07:03 AM
