98 Accord- instrument panel lights and tail lights NOT WORKING
Old Sep 19, 2011 | 02:42 PM
naimperez's Avatar
Default 98 Accord- instrument panel lights and tail lights NOT WORKING
I have a 98 Honda Accord LX. The panel lights do not light up at night after turning the headlights on. I removed the component and replaced ALL the bulbs and still nothing. I bought new fuses and installed them correctly (lol) and the instrument panel still will not light up.
secondly, the tail lights do not come on even after I replaced ALL the bulbs back there. the break lights work fine. not sure what to do next. i checked the connections and they seem fine.
Old Sep 19, 2011 | 05:50 PM
I think that you are going to need a volt meter and a shop manual. I got a shop manual for my TSX from automanualsource.com for $22 and it has all that information about wire colors, etc...
Then you will have to start at a convenient place for electrical testing. I would start at the tail light bulbs that are not working to see if you are missing voltage on the + wire or ground. Then you will have to work backwards to figure out where the circuit is failing.
Old Sep 19, 2011 | 08:29 PM
For the cluster lights, when you get to those, I'd start with the dash dimmer.
Old Sep 20, 2011 | 09:29 AM
naimperez's Avatar
thank you both. i'll get on that and see where it takes me
Old Sep 20, 2011 | 04:11 PM
piggylover1985's Avatar
Are the climate control lights working ?
Old Oct 2, 2011 | 07:01 PM
Murrsive's Avatar
Default ditto
I have the same problem except my tailights work, to fix the tailights i think mine was a fuse on the passenger side, be sure to check fuses with a test light, sometimes the fuse will be blown but still look ok.
ekg98
Dec 20, 2013 10:20 AM
Mook
Mar 6, 2011 06:44 PM
Vegas2TX
Apr 19, 2009 06:28 PM
ButtonMan
Jul 4, 2006 11:51 AM
