'98 Accord Intake plenum clean, now it wont crank
Old Jul 7, 2012 | 04:51 PM
jtrout7's Avatar
Default '98 Accord Intake plenum clean, now it wont crank
I have a '98 Accord V6 2 door. I removed the plenum, and cleaned it thoroughly with tb cleaner. I was getting codes for P0505 and P0401. While removing the throttle body i removed the coolant hose momentarily, very little leaked out. After i was finished i thoroughly checked everything was back in place and tried to crank it. It was almost cranked, but it cut off. I cleared the codes and tried again, but i got a new code P0113. Im wondering if a sensor got wet from the cleaner, or the cleaner hasnt evaporated in the plenum. Im open for suggestions. Thanks in advance.
Jared
Old Jul 7, 2012 | 04:57 PM
Check intake air temperature sensor connector. You likely left it loose. This code is for open circuit on that sensor.
Old Jul 8, 2012 | 06:22 AM
jtrout7's Avatar
Thanks T.H. I checked the sensor and it was connected, but there was some liquid in it so i left it open to dry. Would that cause it to not start, or just run poorly?
Old Jul 8, 2012 | 09:50 AM
jtrout7's Avatar
I took the plenum back off in case there was any more fluid in there. Let it air dry for a bit, and took a blow dryer to the IAT sensor. Plugged it all back, and fired up!! She's running like a top!! Thanks for the help T.H.
razcob
May 8, 2017 11:50 AM
the cyclops
Jul 24, 2011 03:05 PM
livinlifes2short
Jul 20, 2011 04:20 PM
mjl5007
Nov 26, 2010 03:08 PM
xang0
Jul 6, 2009 03:22 PM
