98 Accord LX 2.3 is running rough
Old Apr 27, 2015 | 06:26 PM
mikewohlwend's Avatar
Default 98 Accord LX 2.3 is running rough
Figured I'd ask On here to see if anyone has any ideas. Swapped my motor for a JDM not I can't get the car running right.
It idles fine. When I hit the throttle get to about 2000rpm then just cuts out.
New o2 sensors
new plugs & wires
20150427_170540_zpshtq5vhfp.mp4
http://vid8.photobucket.com/albums/a...pshtq5vhfp.mp4
Old Apr 27, 2015 | 06:49 PM
Is check engine light on? If yes, what codes presented?
Suggest you check cylinder compressions and confirm crankshaft/camshaft timing is aligned.
Make sure spark plug wires are correctly routed.
If you have a scanner, what are Long Term Fuel Trim and Short Term Fuel Trim at idle w/ fully warmed engine?
Old Apr 27, 2015 | 07:28 PM
No scanner. And I have the dash apart currently so I can't see if there's any Check engine codes I can't see them
Old Apr 27, 2015 | 11:40 PM
What are the wire colors going to the map sensor? The throttle position sensor?
Old Apr 28, 2015 | 08:45 AM
I will let you know when I get a chance to check them.
Old Apr 28, 2015 | 10:39 AM
Here is a pic of the map sensor and throttle position sensor plugs.
Old Apr 28, 2015 | 01:15 PM
From looking at pics online and the pics I had on my phone before I pulled the motor I am pretty sure I had those plugs backwards. Changed them around and it revved fine.
Old Apr 29, 2015 | 05:49 PM
When I went to drive the car today it started to Rev eraticly. Now it revs from 1000-2000 rpm consistently.
Old May 2, 2015 | 07:40 AM
That could be because of low coolant or a vac leak. Check the coolant level first.
yankmecrank
Oct 3, 2013 05:05 PM
lordsusanoo
Aug 11, 2010 11:59 PM
thedaveman89
Apr 20, 2009 08:02 AM
clutch811
Apr 16, 2009 06:05 PM
vward24
Feb 15, 2007 09:47 PM
