98 Accord LX Cluster and Power Windows Problem
Old Mar 23, 2010 | 11:04 AM
onlinelinkz's Avatar
Default 98 Accord LX Cluster and Power Windows Problem
Hi
i have a 98 accord lx v4
and just yesterday my cluster gauges and odometer stopped working as well as my power mirrors
wen i put the key in, the battery light and key light appears on the cluster and the cluster itself lights up too but the rest of the lights as well as the gauges are not working
the power mirrors also dont work
and my car is stuck in park
the only way to get it out is by using the shift-lock release
can someone please help me out
thanks!
Old Mar 23, 2010 | 09:59 PM
anyone??
Old Mar 23, 2010 | 10:16 PM
I would check for blown fuses.
The ignition switch feeds power to a lot of those circuits, so that could be a possibility. There was an ignition switch recall on some 6th generation accords (98-02). Yours may or may not be part of the recall. You can call your honda dealership to find out.
Old Apr 14, 2010 | 01:28 AM
Queen eiko's Avatar
I have the exact same problem right now, I have a 91' honda accord LX 2 door. If u found ur problem let me know. I already switched out the ignition switch and theres no change.
Old Apr 15, 2010 | 10:43 PM
it was actually a fuse problem
it was called Backup ACC
i think
just check all of your fuses
Old Apr 19, 2010 | 07:22 PM
Queen eiko's Avatar
Smile
thanks, i have not had time to work on it lately. but all fuses are good unless its an inline fuse? if u remember the location it'd be appreciated very very much!
Old Apr 19, 2010 | 07:41 PM
Your 92 accord is a lot different the 98 accord in the original post.
There are no inline fuses that I know of on the accords. There is a fuse box under the driver's dash. If it is just the gauges not lighting up check the #2 and #8 fuses. The power windows seem to protected with the #5 fuse. I attached a picture of the fuse box.
Attached Thumbnails 98 Accord LX Cluster and Power Windows Problem-fuses.jpg
Old Apr 21, 2010 | 11:21 PM
Queen eiko's Avatar
thank u so much, unfortunately i have no blown fuses under the driver dash or under the hood.. its gotta be some kind of contact that has to do with the key.
coat6
Jun 13, 2015 10:08 AM
patnaik70
Nov 20, 2014 10:34 AM
natwood68
Feb 24, 2014 12:16 PM
th22ek9
Sep 13, 2006 11:11 PM
th22ek9
Sep 8, 2006 09:07 PM
