Gauge cluster, power windows and sunroof don't work and won't shift from park
Old Feb 23, 2014 | 10:56 AM
natwood68's Avatar
Default Gauge cluster, power windows and sunroof don't work and won't shift from park
Hey y'all, I have a 1998 accord ex v6 auto tranny that i am having some issues with. The care has 366K miles on it and was running good until the gauge cluster stopped working along with the power windows, power sunroof, interior dome light and won't shift out of park. I have checked the fuses for the instrument panel and also for the ECU, both are fine. Any ideas guys?!?
Thanks in advance for the quick response.
Old Feb 23, 2014 | 11:17 AM
Check Fuse No. 9 (7.5A) located in the driver's side fuse box.
This fuse protects the following:
Back-up lights, Brake light failure sensor, Clock,
Driver’s and passenger’s multiplex control units, DRL
indicator (Canada), Gauge assembly, Security
system (USA except EX), Shift lock solenoid (A/T)
The moonroof relays need power coming from Fuse No. 9 too.
Old Feb 24, 2014 | 12:04 PM
natwood68's Avatar
I have checked all of the fuses, I do know that fuse 9 is loose but not blown.
Old Feb 24, 2014 | 12:16 PM
What you described points toward that fuse, with a high likely hood of being the source of the problem. The fuse should not be loose.
Do you have a voltmeter or multimeter to check whether there is power or continuity on both sides of the fuse?
coat6
Jun 13, 2015 10:08 AM
aznproto
Mar 16, 2013 06:38 PM
musicrocx09
May 14, 2012 08:32 PM
crimedog76
Jan 4, 2012 06:45 PM
Jonah805
Sep 7, 2011 06:03 PM
