98 EX V6 Cooling Fan not working in drive
Old Jan 29, 2011 | 05:31 PM
  #21
I like to use OEM parts unless the OEM price is outrageous.
The OEM part from the dealership will be about $35. Online are $25 + shipping (so maybe $30 total, but you have to wait)
I would compare the price difference to the aftermarket switch, then make the call.
Old Jan 30, 2011 | 09:00 AM
  #22
I've used lots of parts that aren't in a box with HONDA or SAAB on it. Most times I do some homework try to find out who makes the part for Honda.
For example Denso makes oxygen sensors for Honda. NGK is the OEM spark plug. I've used Gates belts. I don't know who actually makes the fan switches, but I've used Beck/Arnly parts before & they were OK. Sometimes it's difficult to find out who actually makes something.
And why are you afraid of "air bleed"? All you gotta do is open the bleeder screw & allow the air to escape. Hondas do not like to have air-pockets in their cooling systems.
Old Jan 30, 2011 | 02:19 PM
  #23
rolling's Avatar
Thumbs up OEM and air bleed
Hi JIMBLAKE
I guess what I'm about to order either by Standard or Beck is considered an OEM part.... not sure since it's from and online store, not Honda. My Honda Dealer in SF is so marked up. They wand $70 for the part by Nippon! I can get this Thermo including shipping for $16..... so I'm going for it.
Okay about bleeding I believe you or others described the process, so should I do it before or after I get the new part installed? I'm just not used to this car yet. My old Audi was a challenge at times but not like this car.
Old Jan 30, 2011 | 04:47 PM
  #24
The Original Equipment Manufacturer (OEM) thermo switches for your car are:
SWITCH ASSY., THERMO (A-93) (NIPPON THERMOSTAT)
SWITCH ASSY., THERMO (A-93) (UCHIYA)
What you receive from these other parts suppliers may or may not be OEM. Sometimes some OEM parts are just repackaged.
Old Jan 30, 2011 | 05:12 PM
  #25
Bleed the air out AFTER you replace the switch. When you remove the old switch, that's when antifreeze can pour out & air get in the hole.
1 - Be prepared with the new switch, so you can put it in very quickly & only lose a couple ounces of antifreeeze.
2 - Bleed air out after it's all together & after you've run the engine at least a minute or so. The air moves around & eventually collects at 2 places: radiator cap & bleed screw.
3 - WARNIG! DON'T PANIC!!!! (j/k) Bleeding the air out isn't nearly as difficult as you seem to believe.
VW/Audi has their own strangeness. Cooling system doesn't vent out to an atmospheric reservoir. The reservoir is pressurized and the system is arranged so all the air collects in that bottle. Then there's the air-mass-flow sensors...
Or lets talk about Saabs that use the sparkplugs for knock-sensors. Each car company has their strange ways of doing things, you just have to learn what they are & then it's not so mysterious any more.
Old Jan 31, 2011 | 07:34 AM
  #26
bpp's Avatar
bpp
Is there a bleed screw on 6th gen accord V6s? I looked quickly at the fill procedure in the V6 manual and there is no mention of bleed screw (they specifically talk about the bleed screw for the 4 cyl manual).
Old Jan 31, 2011 | 11:57 AM
  #27
uh bpp... You might be right.
At any rate, you'll want to let air out & top up the antifreeze at the radiator cap. Then after a few driving cycles, when the car's cold, squeeze the radiator hoses. You'll hear sloshing if there's air. (IOW, you'd like for it to NOT sound like any air sloshing in there)
Old Feb 3, 2011 | 06:51 PM
  #28
rolling's Avatar
Hi JimBlake, PAHonda. I got the new Therma Switch A and I'm going to replace it Friday morning here in SF time. Other than bleeding the system, is there anything else I need to know going forward with this job? I will need to buy a 24mm socket, do I need any locktite
or etc?
Upon easy installation, how can I easily know that the fan is working at the proper temperature? It might be hard to hear the fan come on when I am driving it. Do you have a method that I should follow to know the problem is resolved? Obviously I know that if the gauge needle doesn't climb, that is one sign. Hopefully I will not see that happen again.
Old Feb 3, 2011 | 07:39 PM
  #29
I think the sensor has an o-ring, so no RTV is needed.
Start the car and drive it around until engine reaches normal temperature. Park the car, let the engine idle. Make sure heater is set to cold and interior fan is turned off. Open hood and see if the two fans turn on before the needle starts moving up.
Old Feb 3, 2011 | 07:40 PM
  #30
The threads on the switch/sensor are "pipe" threads so in theory nothing is needed to seal it....EDIT: and the o-ring helps-sorry PA forgot about that....
Keep an eye on the gauge...then after driving home from worrk or whatever, leave the car running and pop the hood. Might take a few minutes but as the car is sitting still the gauge should climb, just a little, and then the fans-both-should kick on.
