98 EX V6 Cooling Fan not working in drive
Old Feb 10, 2011 | 07:04 PM
  #31
rolling's Avatar
Default Success!
Hi All
Thanks to you all I got the Therma A and put it in. I really was quite easy... the hardest part was finding the 24mm deep socket in stock.
I followed your directions, worked quick, maybe lost a 1/2 pint and closed it up. I studied the area very carefully and never saw a bleed port. It must not be on this model or it's very hidden. Anyway I took my car for a long drive around the city, up and down steep hills and what do you know, the fan came on several times. I stopped the car and listened carefully, and also when I parked it came on in idle. I'm not sure if there is air in the line, I have opened it, and replenished some coolant... I think I squeezed the hoses, frankly I don't know by that if I felt air.
Now if I understand it right the Therma B should not come on after I stop unless it's overheated? Now it isn't coming on as it did before. It's just a redundent switch, right?
Old Feb 10, 2011 | 07:18 PM
  #32
Glad that your problem is fixed.
Thermo B switch turns on the fans only when the engine is turned off. It also turns the fans at a higher temperature compared to Thermo A switch.
The B switch is there to help cool the engine when the car is shut off to prevent damage to the engine. A second switch is necessary due to how the fans are controlled.
Old Feb 11, 2011 | 11:05 AM
  #33
rolling's Avatar
Hi PAhonda
Therm B was turning on the fan as it should, when the engine was off. Now since I put in the new Therm A, the Therm B so far hasn't run the fan, at least in my presence. I'm wondering does Therm B always, upon every shut down turn on the fan, or only when it was really compensating for the problem when the engine was getting overheated? Am I making sense here? Let me know if I can be clearer. I don't hear it come on these days after I shut off the engine, and I'm hoping that doesn't mean it suddenly is out, or if it's just that the engine is running cooler now.
Old Feb 11, 2011 | 12:44 PM
  #34
I think you'll find that after turning off the engine; the fan will only need to run during summertime after the engine is thoroughly hot.
Old Mar 2, 2011 | 03:14 AM
  #35
JonKja's Avatar
Default My many thanks
Thank you as well, after reading countless posts on this website, This was the only posts that had the same problem, I am so happy that I was able to fix this with the help of this site!!! I am a new member and will continue being one.. The repair cost to diagnose and fix this was over three hundred dollars... thank you so much!!!
Old Mar 3, 2011 | 11:13 AM
  #36
rolling's Avatar
Big Bummer! I put the switch in last month as stated, all worked fine. Just last evening I was on my long commute and when I got back into the city in stop and go traffic, the gauge started climbing again and I was overheating. Got home ok and sat in the driveway idleing and the fans didn't come on! The minute I turned off the car they came on. So Therm B is kicking in correctly.... but now what... the new Thermo A switch isn't any good?
Could it be something else is my question, something that is ruining the switch, or just a defective part? I'm on a warrenty so I can replace that brand of switch only as it is an online store. It will be days before I have the new part so please let me know if you think I just got a bad part. I feel defeated!
Old Mar 3, 2011 | 01:08 PM
  #37
What about flaky wiring harness to that switch?
Jumper the wire with a paperclip, turn on the key (fan should turn on). See if you can get the fan to act flaky by moving the wire around??
Old Mar 4, 2011 | 01:51 PM
  #38
rolling's Avatar
Thanks JimB
I did check that out and the wire snap-on doesn't snap all the way down over the plastic therm, so it slipped and it worked it's way loose. I pushed it on as best I could and drove around and the fans started working fine. Stupidly I reordered a replacement and it was shipped before i discovered this, so the new one will have the same misfit. I guess I will use electrical tape to secure it... I guess that will work.
Old Mar 4, 2011 | 02:39 PM
  #39
How about a nylon wire-tie? I bet the electrical tape will get gooey & loosen up with the heat.
What's broken to prevent it from latching? Splice a new plug into the wiring harness?
Old Mar 4, 2011 | 08:42 PM
  #40
Poorman's advise-others have done it as well. Make sure the terminals are making good contact. A drop of silicone on the connector-suggest the outside of the switch or inside the connector-not to the actual pins. Let it cure, then give it a little help with the wire tie (bread or nylon) or something along the same line.
If course Jim has the real answer "Splice a new plug into the wiring harness". Local boneyard and a pair of snips...good to go- I bet they let you out of there for < $5.
