98 honda accord catalytic converter question
Old Jan 26, 2011 | 02:33 PM
  #31
Be careful identifying the pins. There's a couple pins on that connector that can cause an un-fused short circuit & maybe fry the ECU. I thought I've seen a drawing of that connector showing which pins you want; I'll see if I can find it.
Old Jan 26, 2011 | 02:38 PM
  #32
honDUHchick's Avatar
well cleaning the egr didnt do the trick. of course. it is my luck. i guess ill do the converter next even though its not going to fix anything. grr. i took some pics of under my car and under the hood if any one wants me to post
Old Jan 26, 2011 | 02:39 PM
  #33
ok cool.....ill give it a shot. thank you
sorry m kindof losing hope with this turd
Old Jan 26, 2011 | 02:59 PM
  #34
Sure, post the pics.
Old Jan 26, 2011 | 03:15 PM
  #35
it gave me 8 long blinks and then 4 short quick ones. then itd do it all over again
Old Jan 26, 2011 | 03:36 PM
  #36
Old Jan 26, 2011 | 03:37 PM
  #37
Old Jan 26, 2011 | 03:38 PM
  #38
Old Jan 26, 2011 | 03:47 PM
  #39
ok i was wrong i am sorry. i guess its a code 74??? it gave me 7 long blinks and 4 short ones... but random misfire doesnt make any sense......i mean i guess it does.....but its had that code for a lnng time. and then just recently i started it up and it was doing thi crap. i dnt know what to do. i really hope its not bad injectors. maybe one bad injector would be ok, for that 4th cylinder i guess....but theres a stripped bolt on my fuel rail.
Old Jan 26, 2011 | 04:05 PM
  #40
If you pull off the spark plug wires, are there any tubes filled or overflowing with oil.
If you remove the distributor cap, is there oil or a lot of red dust inside of the distributor?
