98 honda accord low pressure switch
Old Jun 10, 2010 | 09:35 PM
kevincraft's Avatar
Default 98 honda accord low pressure switch
can anyone tell me where I can find the low pressure switch for the ac on a honda accord se 97? My air isn't working. The compressor isn't seized and the fuses are good.
Any help is appreciated.
Thanks
PS sorry, the title says 98, but it's a 97
Old Jun 10, 2010 | 09:52 PM
Follow the metal tubes from the firewall near the fuse box towards the battery. The pressure sensor is near the battery. You might be able to get to it easier from under the car (use jack-stands).
Old Jun 10, 2010 | 09:55 PM
kevincraft's Avatar
thanks. How do I trip the switch?
Old Jun 10, 2010 | 10:20 PM
Unplug the switch, it has two wires going to it.
Before jumping it....
Get a volt meter and see if you have continuity (aka ~zero resistance or short) to ground on the yel/blu wire at the pressure switch when the a/c switch is turned on inside of the car.
You can also check the actual sensor while you are down there. The two pins on the sensor should also have ~zero resistance as well even when the car isn't running.
To bypass the switch.... just connect a wire across the two pins of the electrical connector (do this when the car is turned off).
Some other things you should check. Do both fans turn on when you turn on the a/c? Do you have 12V to the wire going to your a/c compressor?
Old Jun 10, 2010 | 11:51 PM
deserthonda's Avatar
first thing,, i would make sure that there is freon in the system ...........
eduard
May 9, 2013 12:11 AM
johnno0213
Jul 18, 2012 06:59 PM
curtie94
Jun 23, 2012 07:52 PM
piconrule
Jul 24, 2009 02:38 PM
HondaAccordNewb
Oct 18, 2007 06:51 AM
