98 Power Window problems
Old May 7, 2013 | 05:33 PM
A member PM'd me and asked that I post the pass front procedure for jumping the window....so "Terry s" here you go
From the pass/right side multiplex on the fuse box:
Verify that A24 and A12 have battery voltage. Verify that A8 has ground.
Front Pass window down: Apply battery voltage to F18
Front pass window up: Apply battery voltage to F9
Attached Thumbnails 98 Power Window problems-6th-gen-pass-multiplex-connectors.jpg
Old May 7, 2013 | 07:54 PM
Terry s's Avatar
Thank you very much. I happen to have front driver side and front passenger side windows not working
so need to see if it is the motor or the switch.
If the motor is bad will I be able to get to the 2 bolts that hold the regulator to the window with the window in the full up position?
The videos I found show removing those bolts with the window down.
Old May 7, 2013 | 08:04 PM
There you are
Do the tests. If the motor/reg is bad there are a few ways to get there......window down/up.
PS- Thanks for joining HAF!
Old Mar 9, 2019 | 12:46 PM
litlerob's Avatar
I realize this is a necro thread. But it is the closest thing to my problem. I have followed this thread and my windows work when jumping the multi-plex, but not with the switch. I bought a used switch from the wrecking yard and it doesn't work either. It's possible that neither of them work, but I was wondering if it might be something else. I checked Ground from the Terminal, I checked Continuity of the Circuit, I fell like I'm answering my own question as I type this.
It's the switch.
But if you have any other possibilities, I'm all ears.
Robert
jkeely
May 2, 2012 03:48 PM
Opballer
Feb 9, 2012 11:54 PM
drew and not u
Jun 24, 2008 01:25 PM
BlackGoose
Jun 11, 2008 07:35 PM
mmazb3
Nov 26, 2007 03:16 PM
