98 SRS Light
Old Sep 14, 2013 | 11:27 AM
RobinsonRicer's Avatar
Default 98 SRS Light
This is for my moms 98 Lx. The SRS light came on and I thought it may have been when the mechanic swapped her ignition switch out since typically you disable the SRS when working around that area.
I checked the fuse and it was fine. Her mechanic said that there is a sensor under the seat that often fails.
How do I pinpoint the problem? And how do I do this without setting off the airbags?
Not much tinkering, I just wanna take a look to see how extensive the problem is. Do the 6th gens have problems with the SRS often?
Old Sep 14, 2013 | 12:35 PM
There is a way of jumping the DLC to get the srs codes.....TX posted is somewhere in the last day or two.
Old Sep 14, 2013 | 10:13 PM
Ok. So SRS has its own codes as well? I thought it was just a light but didn't specify what exactly. I will check his posts.
Thanks
OneEyed
Jun 25, 2015 05:32 AM
brayner
Feb 12, 2013 06:59 PM
01AccordLX
Apr 4, 2012 01:39 PM
01hondaccordlx
May 18, 2005 11:51 PM
bj70alex
Nov 22, 2004 01:56 PM
