99 Accord - Do these O2 sensor charts look somewhat normal?
Old Jun 24, 2014 | 07:12 PM
PeteGibson's Avatar
Default 99 Accord - Do these O2 sensor charts look somewhat normal?
Is there enough data here(or even the right kind of data) to tell if catalytic converter is functioning correctly?
I recently received P0420 code(catalytic converter below threshold) and have since replaced gas cap, pcv valve, up/down O2 sensors. I was not to familiar with my scan tool, so I don't have any data recorded before I made the changes. I do remember that the down O2 sensor seemed to be setting around 0.82v. The code has not come back after 1000 miles. The pdf file contains 3 charts with 50 frames of data. Cruise control setting at 70MPH on relatively flat terrain.
1- O2 sensor voltages
2- O2 short and long term fuel trims
3- Short and long term fuel trims
It looks like the rear voltage was settling down more at around frame 37, but I had to exit.
Old Jun 27, 2014 | 03:30 PM
PeteGibson's Avatar
From reading the forums, I decided to check the IAT(Intake Air Temperature) sensor to see how dirty is was and it certainly need cleaned. The new charts below are just from cleaning sensor. I was surprised to see what a difference it made.
A couple things I noticed about the charts are:
1-O2 sensor voltages chart -- more fluctuation on the low end voltage for the upstream sensor. downstream voltage stayed in same range 0.5 to 0.8
2- O2 short and long term fuel trims chart - entire chart seems to have shifted down 1%.
3- Short and long term fuel trims chart - LT trim percentage went from 3.5-3.0% all the way down to 0.5%. ST trims looks to have dropped 1-2% also.
Both charts were made over the same stretch of highway after 50 miles of highway driving.
Anyway, does this look more normal for functioning O2 sensors and catalytic converter?
JOSHENATOR
Dec 10, 2013 07:01 PM
cleven
Dec 27, 2011 10:48 PM
hanna4209
Nov 27, 2011 10:07 AM
cubias8719
Feb 24, 2007 08:41 PM
WhyNotFab
Oct 4, 2006 03:47 AM
