99 Accord Instrument Lights out
Old May 29, 2007 | 05:38 PM
creeve4's Avatar
Default 99 Accord Instrument Lights out
The Instrument Panel Lights - Tach, Speed, Fuel, and Temp lights all went outat the same time last night, as I was driving on the highway. I checked the fuse and it's good, I removed the instrument panel and replaced the 3 bulbs for these gauges; It is still not working. Any ideas??
Christopher
Old May 29, 2007 | 07:49 PM
Rhoderman's Avatar
Default RE: 99 Accord Instrument Lights out
Most likely your tail lights (park lights, running lights) are out too.
It is unsafe to drive it at night like that.
Check the fuses under the hood too, the instrument panel lights might be on a separate fuse downstream of the tail light circuit. Also, it might be the dimmer circuit. Try rotating the dimmer **** to see if maybe it simply has a bad spot.
Another way to check the circuits would be to turn on the headlights and see if the clock and radio go dim. They get their signal to dim from the instrument panel lights.
And, it would be really helpful if you would post what year of Accord you have. They aren't all the same...
Old May 30, 2007 | 07:47 AM
creeve4's Avatar
It is a 1999 Accord LX
Old May 30, 2007 | 04:50 PM
hondadude's Avatar
any other lights out? audio backlight? clock backlight? AT shifter light?
The 2 fuses to check are Passenger side under dash fuse panel; #10 fuse/ 10 amp and lucky #13 /7.5 amp
This could bemultiplex control unit problem
ekg98
Dec 20, 2013 10:20 AM
naimperez
Oct 2, 2011 07:01 PM
jrock25
Sep 5, 2010 01:27 PM
