'99 accord lost A/C & dash lights
Old Jul 26, 2011 | 11:30 AM
dpz1's Avatar
Default '99 accord lost A/C & dash lights
My A/C goes out while driving along with the dash lights, fan keeps going. Seems like the hotter the outside temperature, the less time it works. It works fine in mornings and late evenings. I checked fuses, changed relays, and added freon but didn't fix the problem. When lights go out, I have no control over defroster, almost got killed yesterday when the lights were out and drove into a rain storm, windows fogged up with no defroster. Suggestions?? Thanx.
Old Jul 26, 2011 | 07:54 PM
A streatch here, but I'd go for a ground issue. Do you have a good manual? Check the Common DIY Threads if not. Also look at the section about HVAC codes .
Old Jul 27, 2011 | 09:03 AM
dpz1's Avatar
I have an average shop manual from a local auto shop. I will check the grounds, however, I am fairly convinced that it is related to some type of sensor because it seems to be heat related. When the outside temp is below 90 it works fine, but when the outside temp gets near 100, it fails rather quickly. Last week when it was 104, it failed in about 30 seconds and didn't come back on. Typical, when you need it most, it doesn't work.
I have seen other descriptions on blogs that seem to fit mine identically, but I haven't seen any results, so there are others with the same issue. I need to get this fixed and don't want to pay a mechanic for 3 hours just to try to figure out what is wrong. Besides, if he and the car are in an air conditioned bay, it won't fail. Thanks for your advice.
dantheman86
Oct 6, 2014 02:15 PM
bbybluluv87
Sep 5, 2013 03:30 PM
KLN
Apr 30, 2013 08:39 AM
drumdoctor
Jan 16, 2012 09:53 AM
Vettress
Jul 7, 2010 11:10 AM
