99 accord would not start.
Old Dec 2, 2014 | 04:54 PM
steamer454's Avatar
Default 99 accord would not start.
Ok new here I have a 99 accord car has new ignition switch. Would not start. Had power on terminal 5 none on 7. Changed main relay. Car started drove it around stopped and would not start. Tried again and started. Don't know if I can trust it.
Old Dec 2, 2014 | 05:13 PM
1. Is this a 4 or 6 cylinder?
2. When you say "had power at terminal 5 none on 7", are you referring to the main relay terminal wires?
Old Dec 2, 2014 | 05:41 PM
steamer454's Avatar
Yes main relay also 6 Cy .Just tried to start and it wouldn't will check relay it's new but could be a dud.
Old Dec 2, 2014 | 05:52 PM
Currently, is there still no power on terminal wire no. 7 (Wht/Grn wire) to the main relay?
Power via the Wht/Grn wire comes directly from under-hood Fuse No. 46 (15A) through a 16-P blue connector (located behind the glove box) to the main relay; and is Hot at all times.
Old Dec 2, 2014 | 06:02 PM
steamer454's Avatar
Ok have power on 7 when I first turn on key then it drops out
Old Dec 2, 2014 | 06:04 PM
steamer454's Avatar
Honda tech told me terminal 7 gets power from contact closing then feeds fuel pump.5 is hot to relay with ignition on.
Old Dec 2, 2014 | 06:25 PM
No.
Terminal no. 7 is where the Wht/Grn wire comes from under-hood Fuse No. 46 like I previously stated. Is there a Wht/Grn wire where you are checking terminal no. 7?
Terminal no. 4 (where the Blk/Yel wire is) provides power to the fuel pump (after the fuel pump relay is energized to close the fuel pump relay contact).
There are actually two relays in the main relay.
Old Dec 2, 2014 | 06:28 PM
steamer454's Avatar
[QUOTE=steamer454;353556]Honda tech told me terminal 7 gets power from contact closing then feeds fuel pump.5 is hot to relay with key on 7 turns on primes and shuts off.
Old Dec 2, 2014 | 06:38 PM
Honda's connector terminal numbering is based on whether the connector is male or female. The cavities (and wire terminals) in each connector are numbered starting from the upper left, looking at the male terminals from the terminal side (or looking at the female terminals from the wire side. Both views are in the same direction so the numbers are the same.) All actual cavities are numbered, even if they have no wire terminals in them.
See attached image of how the terminal numbering is. In addition, another image shows the main relay numbering and wire colors.
Attached Thumbnails 99 accord  would not start.-terminal-numbering.jpg   99 accord  would not start.-main-relay-terminals.jpg
Old Dec 2, 2014 | 06:53 PM
steamer454's Avatar
There is no number 4 . Like I said terminal 7 is yel and black terminal 1 is wh and green. I have power on wh / green my relay has tterminals 1 3 5 7 2 6 8.
