99 v6 ex cuts out while driving
Old Jan 20, 2009 | 09:12 AM
landshark
Default 99 v6 ex cuts out while driving
I have a 99 accord v6 ex coupe. 170k miles. runs great. problem is intermittently. it will die on me while driving. it will then all of a sudden start right back while driving. if i remember correclty it seems that all power went out for that split second. just recently i had to pull over and it starts right back up. the radio was still on though. i have a new battery, changed wires, plugs, cap, rotor. i jiggle the key to see if it's ignition, but it doesn't stall out. i've read here it could be the relay? any other suggestions?
Old Jan 20, 2009 | 11:05 AM
hondadude's Avatar
Default RE: 99 v6 ex cuts out while driving
The first thing you should do is stop by a dealership and ask them to run a VIN status inquiry to see if the ignition switch recall applies or has been done.
The sad thing about that recall is we were installing the exact same units into the cars as was the units that failed, but it made NHTSA happy I guess.
So in fact if the recall has already been done, there is still a chance of ignition switch failure.
Hey, don't shoot the messenger here.
Old Jan 20, 2009 | 11:23 AM
landshark
yep. it was already done during the first recall of them. is that likely the cause?
dmlagrange
Jan 22, 2017 11:11 AM
MAX
Jun 19, 2012 02:16 PM
hcorb29
Jan 22, 2012 02:51 PM
sunsetst
Jul 4, 2011 02:33 PM
thegeneral71
Jun 11, 2011 06:51 AM
