the 9th Generation ADD PADDLE SHIFT 2013 Accord EX sedan
Old May 21, 2013 | 01:35 PM
happymanmen's Avatar
Default the 9th Generation ADD PADDLE SHIFT 2013 Accord EX sedan
the 9th Generation 2013 Accord EX sedan paddle shift
I want to buy the 2013 accord sedan EX and live in Los Angeles, CA. I really need the automatic 4 doors, sunroof and paddle shifter. (Don’t suggest me the coupe EX, I need 4 doors). The sedan Sport with paddle shifter, but there is no sunroof. I have no idea to buy the new car and add the aftermarket sunroof. I don’t know dealer will make special order for sunroof or add paddle shifter.
Can I add the paddle like sport sedan? After I check in Google, nobody do this job before. I also check the part in Honda part link. It shows the same steering part between EX and Sport Sedan. It’s only cost $26 each of paddle shifter. I don’t know it’s only plus and play or need to program it. As I know for sport sedan, when you pull the sport mode, the dashboard will show the gear # during you are driving. If you are full stop with sport mode, it will show you are in 1 gear. I don’t know after I put the paddle shifter in EX sedan, the dashboard will automatic show the gear or need to program the EX sedan to be paddle shift control mode.
I hope anyone can help me.
Thank so much
Sedan EX steering part:
Honda Automotive Parts
Sedan Sport steering part:
Both EX or Sport sedan are same part.
Old May 21, 2013 | 11:19 PM
You will probably have to work with the dealer on this one. My guess is the sport sedan with and aftermarket sunroof is the simplest solution.
I don't think the paddles are just plug and play on the EX sedan. I could definitely be wrong.
The Acura TSX or the Acura TL may be another option to consider.
Old May 22, 2013 | 03:02 PM
That's sure! I don't know dealer will make special order for EX sedan paddle. Also, dealer will make sunroof for about $1900. I don't know dealer will take it for aftermarket sunroof or orginal Honda sunroof.
9thgenaccord
Apr 20, 2014 12:40 PM
9thgenaccord
Mar 6, 2014 10:21 AM
Jet sitter
Apr 13, 2012 06:58 PM
HORSEPOWERJUNKIE2007
Jun 8, 2008 10:47 PM
