_Fast Idle Control Valve_
Old Oct 25, 2006 | 07:09 PM
98accord98's Avatar
Default _Fast Idle Control Valve_
Does anyone know if a 1998 Accord Ex 4cyl have a fast idle control or not? If so, where and how to set it?
Thanks
Old Oct 26, 2006 | 03:16 PM
Electron Man
Default RE: _Fast Idle Control Valve_
Yes the 4cyl Accords (98-02) have a fast idle solenoid. If your idle is too low (rpm below ~600), it might've failed...I had one on a '99 LX go bad.
If your idle speed is too high after the engine has warmed up completely, look for a screw on the throttle body to adjust the idle lower.
As far as I know, there is no adjustment to the Fast Idle Control Valve. If idle is still too high, perhaps you have a leak allowing false air somewhere (check hoses on intake manifold).
Old Oct 26, 2006 | 03:46 PM
98accord98's Avatar
thank for the reply. yeah, i did find the idle control on the throttle body and adjust it to the min and the lowest it can go is to 900 rmp. do you know what the normal idle rmp should be at?
Old Oct 30, 2006 | 02:37 AM
98accord98's Avatar
I found the leak! It was throught the throttle body plate. Does anyone know if that plate is adjustable, meaning, is there a screw to make the plate close tighter?
ps. I had the idle control to the min already.
Old Oct 30, 2006 | 05:54 AM
YeuEmMaiMai's Avatar
normal idle is about 750-800 rpm...
Old Oct 30, 2006 | 02:09 PM
There's usually some kind of stop at the throttle-cable drum. The purpose of that is only to prevent the throttle plate from getting wedged (stuck) in the throttle bore. If someone has used that to adjust idle rpm, you may have to undo their 'work'...
Clean out the throttle plate & bore. If it's all gunked up, maybe that's why someone wanted to adjust it??
Brash
Jun 24, 2012 04:26 AM
raf105
Sep 28, 2007 02:55 PM
greenbean
Sep 21, 2007 03:14 PM
Gabino
Sep 11, 2006 02:09 PM
collierville
Aug 17, 2006 10:37 AM
