ABS accumulator leaking
So I have the infamous accumulator leak on my 94 Accord ex. I've bought the O-ring that seems to always be the culprit and plan on taking this thing apart this weekend to replace it. I was wondering if any of you guys have done this? If I can fix this with a $1.00 o-ring I'll be happy to save the over 200 bucks which I would need to buy a new accumulator.
Any comments would be great!
Cheers
Cheers
I"ve never done that repair myself but it appears fairly straightforward, also, if you need a manual or want one then here are a few freebies
http://www.hondahookup.com/manuals/
http://hondatech.info/downloads/Auto/Manuals/Accord/
ORIGINAL: sir_nasty
Be sure to have a couple cans of brake clean spray on hand and rags to put under the lines as you take them loose, brake fluid eats paint and you need to be sure to clean off any spillage.
One of the lines will drain the brake master cylinder. If you want to, empty it first with a turkey baster or suction pump it will save some mess later in the job.
We are talking total brake fluid mess. Fender cover is highly recommended
93Accord2.2
Nov 7, 2013 07:10 AM
