Leaking Trunk
Old Jan 27, 2006 | 12:35 PM
xbombtek
Default Leaking Trunk
Has anyone ever heard of Accords (1993) having issues with a wet trunk?
My gasket is good around it. It just gets wet in no particular pattern. I have even resorted to getting in the trunk and having the wife just drench it with a hose and I see nothing.
But it pretty much stays moist (at a minimum).
Any suggestions?
Thanks All,
Marty
Old Jan 27, 2006 | 05:02 PM
bobs87's Avatar
Default RE: Leaking Trunk
I'm going through the same thing now with my '87--I found 3" of water in the spare tire well. I pulled everything out of the trunk and checked the gasket during a rainstorm but couldn't see any leaks. I did see a couple drops of water dripping from the brake light assembly gaskets and replaced those, but that isn't the main source of the leak.
I did see a rectangular "vent" in the left side if the trunk, with what looks like a one way rubber flapper valve (to vent air out of the trunk?), and it looked like water was leaking into the trunk around it's edges. I'll check this out this weekend.
Bob
Old Jan 28, 2006 | 03:45 AM
marbro's Avatar
The vent in the rear of the trunk is intended to vent out moisture even tho it still acts as a 2 way door. Im going to end up punching mine out and welding a plate over it considering my second battery is sitting right next to it...............
Old Jan 28, 2006 | 07:31 AM
lightshow's Avatar
yea the vent is where i would look. if it stops sealing correctly then water would be allowed to enter when it shouldnt.
lightshow
Old Jan 29, 2006 | 08:19 PM
Fez's Avatar
Fez
I've got a '93 with the same problem. I'll check out that vent and see if a quick Duck Tape fix will stop it and then figure out a more permanent solution if that is indeed the problem. For now, cleaning all the nasty carpet and mildew out will be my first task... it's so gross.
I'll put an update here when I make some headway.
thaison86
Jun 28, 2012 12:03 AM
mixedboy88
Jun 17, 2012 03:16 AM
gnedison
May 28, 2012 07:26 AM
crack3d
Jan 17, 2010 04:10 PM
MNHONDAGUY
May 8, 2007 07:52 PM
