Trunk leaking
Old May 15, 2012 | 12:22 AM
gnedison's Avatar
Question Trunk leaking
Hi all,
I am new on here so bear with me. I recently bought a 2006 accord ex V6 with a deck spoiler. Water is leaking into the trunk every time i wash it or when it rains. I haven't been able to locate the leak. Are there any tips out there as to what could be the cause.
Thanks,
gne
Old May 15, 2012 | 12:27 AM
crispin's Avatar
Hello -
This doesn't seem like an "off Topic" topic
Most water comes in because the taillight seal has started to leak
However as you have a spoilier I would also check there
Old May 15, 2012 | 01:25 AM
Nitehawk Girl's Avatar
My trunk was also leaking, I too have a deck lid spoiler, the bolts were starting to wear and had to be replaced...so far so good they were sealed too..hope this helps..
Old May 15, 2012 | 08:34 PM
gnedison's Avatar
Thanks for the replys. I will check both avenues. I sure hope one turns out to be the culpret. I can't keep driving around with the trunk lid up, to dry it out. HA! HA!
Old May 15, 2012 | 08:50 PM
crispin's Avatar
I think if I was you I would pull the spoiler off and reseal it with black gasket maker.
try not to use too much of it, just a light coating on the existing rubber gasket.
Old May 27, 2012 | 10:10 PM
GoneHonda's Avatar
How do I stop the tail lights from leaking? I have the same problem, only mine have been not fixed for whothehell knows how long from PO
Old May 28, 2012 | 07:26 AM
New tail light gaskets or re-seal your old ones with silicone.
thaison86
Jun 28, 2012 12:03 AM
mixedboy88
Jun 17, 2012 03:16 AM
crack3d
Jan 17, 2010 04:10 PM
MNHONDAGUY
May 8, 2007 07:52 PM
xbombtek
Jan 29, 2006 08:19 PM
