ABS accumulator leaking
Old Jan 18, 2007 | 01:41 PM
walker111's Avatar
Default ABS accumulator leaking
So I have the infamous accumulator leak on my 94 Accord ex. I've bought the O-ring that seems to always be the culprit and plan on taking this thing apart this weekend to replace it. I was wondering if any of you guys have done this? If I can fix this with a $1.00 o-ring I'll be happy to save the over 200 bucks which I would need to buy a new accumulator.
Any comments would be great!
Cheers
Old Jan 18, 2007 | 01:46 PM
sir_nasty's Avatar
Default RE: ABS accumulator leaking
I"ve never done that repair myself but it appears fairly straightforward, also, if you need a manual or want one then here are a few freebies
http://www.hondahookup.com/manuals/
http://hondatech.info/downloads/Auto/Manuals/Accord/
Old Jan 18, 2007 | 01:50 PM
walker111's Avatar
ORIGINAL: sir_nasty
Thanks for the links, checking that out now!.... Although, I've never found a manual stating how to take the abs apart..
Old Jan 18, 2007 | 02:00 PM
sir_nasty's Avatar
Let me know if this helps....
http://www.hondapartswarehouse.com/p...%20%2024%20%20
Old Jan 18, 2007 | 10:13 PM
hondadude's Avatar
Be sure to have a couple cans of brake clean spray on hand and rags to put under the lines as you take them loose, brake fluid eats paint and you need to be sure to clean off any spillage.
One of the lines will drain the brake master cylinder. If you want to, empty it first with a turkey baster or suction pump it will save some mess later in the job.
We are talking total brake fluid mess. Fender cover is highly recommended
93Accord2.2
Nov 7, 2013 07:10 AM
wunderbra
Aug 24, 2013 06:01 PM
MichaelT1960
Mar 26, 2008 07:02 PM
St3v3
May 14, 2006 04:05 AM
xbombtek
Jan 29, 2006 08:19 PM
