Sponsored by:
Sponsored by:
ABS Code 44 Wheel Sensor Rear Right - '94 Accord
Old 02-05-2013, 04:25 PM
blaze739's Avatar
Default ABS Code 44 Wheel Sensor Rear Right - '94 Accord
First off, big thanks to TexasHonda for helping me read my ABS code. I am getting code 4 4 (Wheel sensor Rear right) from my ABS light. Does anyone know what this means and what the fix is?
When i bought the car, I noticed the right rear brake disc accumulating rust so it doesnt seem like the pad is applying pressure. i replaced the brake fluid and bled all four brakes but it only seemed to help alittle.
any help is appreciated. thanks.
Old 02-05-2013, 04:57 PM
If the pad isn't applying pressure, that's separate from the ABS sensor. You can remove the caliper, take out the brake pads, & clean everything up.
Clean & lubricate the caliper slide pins, with silicone brake grease.
Clean the brake pads, make sure they fit nice, and they don't wedge tightly stuck in the caliper bracket. Maybe a little grease where they fit into the bracket. NO GREASE on the friction surface (you probably already know that).
There's only one electrical wire back at the brake caliper, and it's the ABS sensor. Look for cut/torn wires? Look for dirty/loose/corroded plugs? You might have to go underneath the trunk carpeting to find the first electrical plug.
If you remove the brake rotor you can probably see the sensor - it's magnetic & reads a toothed ring that spins with the wheel. Clean it up if it's got a bunch of metal shavings stuck to it.
Old 02-05-2013, 05:56 PM
blaze739's Avatar
I tried cleaning and greasing the calipers several months ago when i changed the pads, but the sliding pin still wasnt functioning too well. it definitely got a little better, but not perfect. i also have a bad master cylinder that i will be replacing within the next couple weeks so maybe that will help.
i'm going to try cleaning the sensor this weekend and see if that addresses the ABS light. thanks for the help.
Old 02-05-2013, 08:23 PM
Pull wheel sensor and clean w/ solvent. Also stuff rag into wheel sensor hole, and turn wheel to clean tone ring. Dirt on tone ring can also cause problems.
Old 02-06-2013, 08:21 AM
blaze739's Avatar
i'll give it a shot this weekend. thanks again.
Old 02-07-2013, 06:05 PM
While there you could also measure the resistance of the sensor? Follow the wire back from the sensor at the wheel. There is an orange (I think) connector almost at the center of the car......test the resistance of the wires going to the wheel sensor.
Spinninwrenches
12-08-2011 01:14 PM
Dieselpro
05-19-2011 09:23 PM
madsteez
01-18-2009 07:43 PM
bogeymiang
12-11-2008 04:55 PM
killersoundz
12-08-2008 12:51 PM
Quick Reply: ABS Code 44 Wheel Sensor Rear Right - '94 Accord
