ABS Flashes Twice in Diagnostic mode, can't find what code that is
Old May 3, 2013 | 06:17 PM
dlite922's Avatar
Question ABS Flashes Twice in Diagnostic mode, can't find what code that is
Hey guys,
New here, old to Hondas. I don't have a scanner so I jumped PINs 9 and 4 on OBDII port of a 2000 Accord 4 Cyl Sedan. (Could not find the double PIN blue connection under glove box in this car )
Thought this would be enough to show me a code but through this forum I found that some brake pedal action is required similar to resetting the SRS light (hold pedal in, turn on key, release pedal when ABS light goes off, press again when light comes back on, and finally release one last time when it goes off. What should flash next should be the ABS code)
However, the ABS light flashes twice and goes off until the car is driven past 10 MPH.
I could not find for the life of me what 2 slow flashes mean. That would be a code 20 but I searched on this form and none of the code lists have 20 in them.
Any clues?
Thanks experts,
Old May 3, 2013 | 06:39 PM
I'll guess the code is 11, reading abs codes is a bit different.
11 is for the right/pass front wheel sensor.
Oiler1
Apr 20, 2016 05:29 PM
Custnam
Oct 28, 2012 12:50 PM
Abhishek719
Nov 27, 2011 11:08 PM
jackfast
Feb 3, 2009 08:33 PM
ddold@gkschools.org
Jan 29, 2008 03:35 PM
