ABS light codes on 94 Accord
Sure no problem, I have Alldata on my other computer here; However it does require me to roll my chair 3 feet to the left, but I'll make the effort for ya
The code will blink in 2 parts, main system and then sub system.
An example is 5 blinks then 4 blinks is a code 5-4
Here ya go...
1 -ABS pump motor over-run
1 2ABS pump motor
1 3high pressure leakage
1 4pressure switch
1 8high pressure system
2 1parking brake
3 1pulser RF
3 2pulser LF
3 4pulser RR
3 8pulser LR
3 12different diameter tires
4 1wheel sensor RF
4 2wheel sensor LF
4 4wheel sensor RR
4 8wheel sensor LR
5 -rear wheel lock - R/L
5 4rear wheel lock - R
5 8rear wheel lock - L
6 -fail-safe relay - F/R
6 1fail-safe relay - F
6 4fail-safe relay - R
7 1solenoid - RF
7 2solenoid - LF
7 4solenoid - R
8 1ABS function
8 2CPU comparison
8 4IC self-check
1 2ABS pump motor
1 4pressure switch
2 1parking brake
3 1pulser RF
3 2pulser LF
3 4pulser RR
3 8pulser LR
4 1wheel sensor RF
4 2wheel sensor LF
4 4wheel sensor RR
4 8wheel sensor LR
7 1solenoid - RF
7 2solenoid - LF
7 4solenoid - R
8 1ABS function
8 2CPU comparison
8 4IC self-check
how do you check for the abs code? like how do you get it to flash? cuz on my accord, my ABS light is on...and i dont know whats wrong with it...if the ABS is working, you wouldnt be able to lock your tires and skid right?
Same procedure as for the check-engine light...
Find the SCS connector. I don't have a '94 but think its behind the ashtray or something like that? Blue plastic plug with 2 wires, not plugged into anything but held in a rubber socket.
Jumper that SCS connector with a paperclip. Turn the key to ON (no need to start the car). Check-engine light will flash it's error codes with long=10 & short=1 & long pause between different codes.
While that's happening, the ABS lamp will flash out it's own code. One flash & one long paust (that's not part of the code yet). Then you get short flashes for first digit, pause, short flashes for 2nd digit. Then a long pause. Then the next code, etc.
On the 94 Accords, the Service Check Connector (why does Honda use SCS abbrev?) is under the glove box. Male end is plugged into a fixed female holder. Pinchmale end connector and remove to short.
93Accord2.2
Nov 7, 2013 07:10 AM
tiotico
Jul 31, 2012 08:04 PM
