ABS light codes on 94 Accord
Old Jun 2, 2008 | 07:41 PM
Evlampius's Avatar
Default ABS light codes on 94 Accord
Hi guys,
does anybody have the codes chartfor ABS light blink? Or can read it from a chart if I tell you the code? My boss sent ALLData away
thanks
Old Jun 2, 2008 | 08:52 PM
hondadude's Avatar
Default RE: ABS light codes on 94 Accord
Sure no problem, I have Alldata on my other computer here; However it does require me to roll my chair 3 feet to the left, but I'll make the effort for ya
The code will blink in 2 parts, main system and then sub system.
An example is 5 blinks then 4 blinks is a code 5-4
Old Jun 2, 2008 | 10:42 PM
Here ya go...
1 -ABS pump motor over-run
1 2ABS pump motor
1 3high pressure leakage
1 4pressure switch
1 8high pressure system
2 1parking brake
3 1pulser RF
3 2pulser LF
3 4pulser RR
3 8pulser LR
3 12different diameter tires
4 1wheel sensor RF
4 2wheel sensor LF
4 4wheel sensor RR
4 8wheel sensor LR
5 -rear wheel lock - R/L
5 4rear wheel lock - R
5 8rear wheel lock - L
6 -fail-safe relay - F/R
6 1fail-safe relay - F
6 4fail-safe relay - R
7 1solenoid - RF
7 2solenoid - LF
7 4solenoid - R
8 1ABS function
8 2CPU comparison
8 4IC self-check
Old Jun 4, 2008 | 12:49 AM
ford's Avatar
how do you check for the abs code? like how do you get it to flash? cuz on my accord, my ABS light is on...and i dont know whats wrong with it...if the ABS is working, you wouldnt be able to lock your tires and skid right?
Old Jun 4, 2008 | 07:42 AM
Same procedure as for the check-engine light...
Find the SCS connector. I don't have a '94 but think its behind the ashtray or something like that? Blue plastic plug with 2 wires, not plugged into anything but held in a rubber socket.
Jumper that SCS connector with a paperclip. Turn the key to ON (no need to start the car). Check-engine light will flash it's error codes with long=10 & short=1 & long pause between different codes.
While that's happening, the ABS lamp will flash out it's own code. One flash & one long paust (that's not part of the code yet). Then you get short flashes for first digit, pause, short flashes for 2nd digit. Then a long pause. Then the next code, etc.
Old Jun 4, 2008 | 12:24 PM
On the 94 Accords, the Service Check Connector (why does Honda use SCS abbrev?) is under the glove box. Male end is plugged into a fixed female holder. Pinchmale end connector and remove to short.
93Accord2.2
Nov 7, 2013 07:10 AM
tiotico
Jul 31, 2012 08:04 PM
g22cd5
Sep 26, 2011 07:52 AM
bjr001
Feb 27, 2011 03:41 PM
jdwilson4
Jan 8, 2009 09:14 PM
