ABS Light coming on???
Old Mar 30, 2012 | 03:38 PM
Swedevil's Avatar
Default ABS Light coming on???
'96 accord 2.2 vtec
I picked the car up and it has had an abs light every since I got it. You turn the car on and can hear what sounds like a compressor leaking air (might not pertain to it) and after about 30-90 ofthe car being on, you hear a click and the abs light comes on. Any ideas of what to check and how???
Old Mar 30, 2012 | 05:22 PM
Check for ABS codes. Short service check connector and ABS light will flash the codes. First a long test flash, then short flashes (f) and short pause (p) to code the first and 2nd digit of code. For instance ffff-p-f=4-1.
Check DIY forum for procedure to extract Check Engine codes. Same procedure except flash code is different and different indicator light.
Post the code back for additional guidance.
Old Mar 30, 2012 | 06:32 PM
Swedevil's Avatar
I'm a little confused as FI what a short service check connector is. Just an ODB scanner?
Old Mar 30, 2012 | 06:39 PM
Old Mar 30, 2012 | 06:56 PM
Swedevil's Avatar
I'm not trying to be rude, but I did read that. I just don't understand what to hook up to get the light to start flashing.
Old Mar 30, 2012 | 06:57 PM
crispin's Avatar
Under the glovebox is a gray or blue connector that is not plugged into anything.
Use a paperclip to connect those two wires together.
Old Mar 30, 2012 | 07:18 PM
Swedevil's Avatar
And the flashing will begin? Seems a little bit um...redneck, but will have a go at it...thanks
Old Mar 30, 2012 | 09:22 PM
crispin's Avatar
I do not think they have rednecks in Japan where the system was designed.
If it is below what you think should be done you can drive your car to Autozone and they will scan the codes for you in a less-Redneck way if you wish.
93Accord2.2
Nov 7, 2013 07:10 AM
Winston Hart
Sep 7, 2013 12:32 PM
bobbybriggs01
Aug 21, 2013 06:14 PM
JJC
Mar 13, 2013 06:17 PM
NINguy720
Jul 31, 2010 12:29 AM
