ABS light - tried search already
Old Feb 15, 2008 | 07:50 PM
walmark
Default ABS light - tried search already
I have an ABS light on intermittently. I just went down to check the code and it said 1-8. I tried the search but there is a bunch of ABS posts and the search excludes "1-8" or "18". Did any of you have experience with that code? Is there anything I can do aside from replacing multi-thousand dollar part on a 2,500 dollar car? Thx in advance
Old Feb 15, 2008 | 11:22 PM
Default RE: ABS light - tried search already
The DIY section has an ACC 5th gen post with a link to an online manual. The pdf with some instructions on 19-84.
Basically you want to check the relief plug and the accumulator.
Does the ABS unit leak brake fluid at all? I remember reading about the O-ring on the accumulator failing, but I am not sure if this will cause a code 1-8.
Old Feb 16, 2008 | 05:23 AM
This may indicate the accumulator has lost charge. You can find used modulators for very reasonable prices using car-part.com and searching for sources near your zip code. I had to buy two to make one good modulator for a total investment~ $120. If you can get a garuntee of a working part, but the vendor can't really know if the modulator is working when sold.
There is a TSB for leaking modulator body plugs that affects quite a few modulators. You should loosen, clean, and tighten all the body plugs (about 9 I think) before installing.
Old Feb 16, 2008 | 04:45 PM
walmark
I have to say I don't really understand that system. What is that high pressure nitrogen acumulator for? And if it lost pressure, why can't it just be recharged? I looked in the service manual for code 1-8 but all three steps led to "replace modulator". The site sponsor has a remaned one for $1000 (!), and I believe new ones are closer to $8000... About junkyards - how do you know how much "pressure" is left in their stuff?
Old Feb 16, 2008 | 07:44 PM
Regarding salvage yard modulators, you don't know anything about their condition other than what can be observed. As I said, I bought two to make one good modulator. One had a bad motor and other had an internal leak. They're cheap enough to justify, but I would try to extract a "working unit garuntee" from the salvage yard. They may allow you to get your money back if it's dead, or swap for another unit.
Accumulator is factory charged w/ N2. I don't think it can be recharged. If it leaks it means the seal separating N2 from fluid is bad in any case.
numaone
May 23, 2014 02:51 PM
93Accord2.2
Nov 7, 2013 07:10 AM
Chgoaccordguy
May 19, 2013 03:42 PM
Tuttlebot
Dec 30, 2011 08:49 PM
djfunkyfritz
May 10, 2008 08:51 AM
