ABS linked to VSS on a 94?
Old Mar 24, 2013 | 12:06 AM
skyfire322's Avatar
I'll take a video and post it on here
Old Mar 24, 2013 | 04:18 PM
skyfire322's Avatar
Okay, so I checked it out again today, and the ABS trouble codes were 1 3, and 1 4. High pressure leakage, and pressure switch respectively.
The one thing I'm still not getting though is why the CEL isn't giving any codes at all. I sat there for a few minutes, and the CEL just stayed on. I have a gut feeling something is going on, because the car feels and sounds like there's a dead cylinder.
Old Mar 24, 2013 | 05:41 PM
Well can we back up a minute and really get into this.
You have abs codes for the motor, I posted already some things to try.
Why do you feel there is a "dead" cyl.....once warm the engine has a miss at ~2000 rpms? If you hammer the gas pedal there is no issue?
Old Mar 24, 2013 | 06:17 PM
skyfire322's Avatar
If the weather cooperates tomorrow, I'll take a look at the fluid levels and do the bleed
I apologize if it seemed I was jumping the gun!
Old Mar 24, 2013 | 08:44 PM
I probably messed up the process. I was confused when skyfire talked about long & short flashes. As shown in Poorman's picture, the sequence begins with a long flash that isn't part of any code. The actual codes are all short flashes.
Check the stuff that Poorman suggested, come back & if needed we can make additional suggestions.
Bleed the ABS fluid and see what happens.
Old Mar 25, 2013 | 06:31 PM
You didn't jump the gun....Sorry if my post came across that way. Code 1, with or without sub codes can be many things. I was only trying to say that a bleed of the ABS system - Jim has a write up on it - is the best place to start IMO. I have a pdf of a service bulletin on this but it is a pdf and too large to attach, do a goggle serach for "93-038 service bulliten".
If could turn out to be something else but a bit of time and a some fresh brake fluid could make it go away. I'll let you value your time but the ~$5 in brake fluid is a cheap try.
For the "dead cyl" - can you give us more details on this? I have nothing to go on besides the generation and a guess at the miles on the car. Read about clogged egr ports on these Accords and see if that "fits" with what you are feeling?
93Accord2.2
Nov 7, 2013 07:10 AM
94exsedan35094
Feb 5, 2008 08:44 AM
comptoncarl
Feb 8, 2007 03:04 PM
JWW512
Jul 23, 2006 01:04 AM
cbriley3
Oct 23, 2005 11:04 PM
