abs pump?
Old Feb 18, 2013 | 11:04 AM
blumule's Avatar
Default abs pump?
daughters 94 accord v tec abs light has been on for a month or two with no apparent leaks or problems. came home friday , said car was running bad and shaking at idle. i inspected and noticed abs module cycling on and off continuosly causing a pull on motor, hence the rough idle. i jumped connecter and got the 1 pause 2 light blink. im understanding this is the pump. could it be anything else? i pulled the relay so she could drive it. is that a problem? is the pump the whole abs box at front left corner ?
Old Feb 18, 2013 | 06:40 PM
I'd check the fluid level in the abs res...then I would bleed the abs unit.
Was the abs light on? If so get the codes after checking the fluid and blleding.
93Accord2.2
Nov 7, 2013 07:10 AM
Honda Accord94ex
Nov 18, 2010 06:18 PM
Senior Taco
Nov 5, 2009 10:56 AM
louofm1
Mar 6, 2008 03:15 PM
rcy
Mar 23, 2007 10:41 PM
