ABS Sensor Replacement
Old Jan 6, 2012 | 11:55 AM
wings's Avatar
Default ABS Sensor Replacement
Hello,
I have a '93 Accord, Auto, 116K.
I think I have a bad front abs sensor. When I'm braking, when I almost get to a stop, the abs brakes of the passenger front brakes will activate, despite being on dry pavement. I'm worried about burning out my pads/caliper prematurely, so I'm going to replace the abs sensor.
I have an old one laying around from an old steering knuckle that I ran across and I'm curious if it's a plug 'n chug operation. Any suggestions and/warnings? Things I should know about?
Thanks!
Old Jan 6, 2012 | 01:07 PM
Its pretty simple DIY. Use some kind of penetrating oil on the two bolts, as they can become rusty.
I would first look for a buildup of grease/dirt on the original sensor and on the metal strap with little teeth on the CV joint. That could cause the ABS sensor to pick up a false signal. It is worth a shot.
Old Jan 6, 2012 | 03:14 PM
If tone ring (ring w/ gear like teeth) is dirty, you can clean by stuffing a rag down the sensor opening and turning the wheel by hand.
pondrun
Nov 8, 2021 09:40 AM
93Accord2.2
Nov 7, 2013 07:10 AM
lmrj0030
Dec 25, 2011 08:19 AM
kingkohlmn
Mar 6, 2011 08:13 AM
T WILD
Jun 10, 2009 06:45 AM
