ABS & SRS codes
Old Feb 26, 2011 | 05:45 PM
bjr001's Avatar
Default ABS & SRS codes
I jumped the blue connector under the glove compartment and received the following:
I have the following ABS light flashes:
Long =1
Short = 4, 8, 1
I have the following SRS light:
Long =8
Short =5
What do these codes signify?
Old Feb 26, 2011 | 05:55 PM
I would download the 94 shop manual from the spooner link posted in the online manuals thread in the DIY section.
For the ABS, the first long blink is a bulb check and not a code.
The next code is a 4-8 which is a problem with the driver's side rear wheel sensor. A code 1 is an ABS pump over-run. Diagnose both of these. Don't blindly replace.
4-8 - there is a resistance test. Check loose sensor at the wheel. Dirty, corroded, or lose electrical connection?
Code 1 - check the brake fluid level in ABS reservoir.
The SRS code 8-5 is a failure of the SRS control unit. The only fix in the shop manual is to replace the unit.
Old Feb 26, 2011 | 07:00 PM
bjr001's Avatar
I'm unable to find this "spooner link" in the DIY area. Please advise.
Old Feb 26, 2011 | 08:01 PM
Open the thread called online manuals in the DIY section. The link I referenced is in the first post.
Old Feb 27, 2011 | 03:02 PM
bjr001's Avatar
I have a Mac running OSX and using Safari. There is no on line manuals that I can see. Would appreciate help, even private message me.
Thanks
Old Feb 27, 2011 | 03:41 PM
Copy and paste this into your browser.
hondatech.info/downloads/Auto/Manuals/Accord/
Download the 3rd in the list. The file is called: Ab0VE Honda Accord 1994 zip 44.74 MB
ericj
Sep 28, 2012 07:24 AM
stueyvtec
Oct 20, 2010 08:02 PM
PAhonda
Oct 19, 2009 11:26 PM
JeffB
Feb 3, 2008 01:00 PM
01hondaccordlx
May 18, 2005 11:51 PM
