abs & srs lights stuck on
Old Oct 20, 2010 | 10:40 AM
stueyvtec's Avatar
Exclamation abs & srs lights stuck on
can any one help me get my ABS light off it only came on when i had a new CV fitted. and i dont seem to have a diagnostic socket loads of people have looked and cant find one (HONDA ACCORD V-TEC 1999) ALSO MY srs LIGHT IS STUCK ON (was on when i bought car 3mths ago)cant get it off please help is there a diog-socket on this model i was told there isnt.,,
Old Oct 20, 2010 | 02:26 PM
The abs and srs lights turning on means there is a problem detected. The abs light is likely due to the new CV joint installation. Did the new CV joint have ribs on the metal clip so the abs sensor can detect wheel movement?
The SRS light tuned on means the SRS computer detected a problem.
You should get the code(s) scanned to figure out the problem.
The ABS and SRS codes may be something only a dealership can scan. An independent shop that specializes in Hondas/foreign cars may be able to scan for codes as well.
Parts stores will scan codes for free, and they might be able to scan those codes. It is worth a shot to see if they can get the codes.
Old Oct 20, 2010 | 08:02 PM
Not sure about 99 model, but on earlier models the ABS code/s could be retrieved by shorting the service check connector under the glove box. The ABS light will flash the codes; Long start flash means system OK, then long flashes + short flashes for codes (3-1) LLL-s.
Use google to search for "RSX SRS code". You should find info to read codes and reset SRS for many Honda/Acura products.
dantheman86
Oct 6, 2014 02:15 PM
JJC
Mar 13, 2013 06:17 PM
Antiriad
Jul 6, 2012 09:00 AM
bjr001
Feb 27, 2011 03:41 PM
01hondaccordlx
May 18, 2005 11:51 PM
