ABS and TCS lights came on last night...
Old Jun 27, 2013 | 07:38 AM
shipo's Avatar
Default ABS and TCS lights came on last night...
Hey Gang,
I Drove to work yesterday with no issues or stray idiot lights; got in the car last night to drive home and the instant I started the car the ABS and TCS lights came on and stayed on. Annoying.
Is this a common issue for 2001 V6 Accords? Is the answer typically an ABS wheel speed sensor, or is it more like a pricey control unit?
Thanks in advance for the help.
Old Jun 27, 2013 | 03:26 PM
Dr. Drivability's Avatar
a simple place to start with is check the R/C mirror fuse in the underdash fuse panel (7.5amp) if it's blown, replace it.
Old Jun 27, 2013 | 06:40 PM
Not absolutely sure, but suspect ABS codes can be extracted manually same way as earlier models; shorting service check connector and watching codes. On earlier models, ABS codes are all short flashes w/ a pause between 1st and 2nd digit; 4-4 = ffff-p-ffff.
If you don't have a service check connector, you may need to short pins on obd2 connector (4-9). See folllowing link:
http://forums.clubrsx.com/showthread.php?t=636707
Old Jun 28, 2013 | 07:44 AM
shipo's Avatar
Thanks folks, I'll have a look-see this weekend.
ziggy!talon
Dec 15, 2008 06:52 PM
importedminds
Jun 30, 2008 07:04 PM
Tony1M
Jan 30, 2008 01:15 PM
214texas
Nov 26, 2007 10:39 PM
Chiovnidca
Apr 2, 2007 10:54 PM
