ac compressor
Old Jul 7, 2014 | 10:11 AM
thetowerxxx's Avatar
Default ac compressor
Help im new here i have a 98 honda accord 6cyl vtech. My ac compressor needs to ne replaced but i dont know the type or model the ac compressor is i have found a full ac compressor kit but idk if it will work for my car
http://www.rockauto.com/catalog/moreinfo.php?pk=3925476&cc=1315593
Old Jul 7, 2014 | 11:54 AM
djkurious's Avatar
First, what is the issue with the compressor? Did the first one lock up?
Has the system been checked with a A/C gauges? Have you tried to charge the system?
Has the system been exposed to moisture? When replacing or opening A/C system, always replace drier.
Old Jul 7, 2014 | 12:50 PM
Rockauto specifies Denso 10PA17C and Denso 10S17C compressors as replacement. I looked at Majestic Honda and Honda part no. is 38810-P3G-003.
You can rely on Rockauto to sell you the correct compressor.
Also agree that you should describe your problem to be sure you need a compressor.
Do you plan to DIY installation/charging? Do you have necessary tools?
Old Jul 8, 2014 | 09:01 AM
I took it a meineke they told me the system is pretty much gone but they wanted to charge me $1200 for everything but they also told me that they would do the work if i bring in the parts. Thank you for the replys
Old Jul 8, 2014 | 12:16 PM
djkurious's Avatar
Question: why go to Meineke for A/C work?
Old Jul 10, 2014 | 10:58 AM
UhOh's Avatar
Agree, fully.
If I were having A/C repaired, I'd go to the Honda dealer, or a shop that specializes in A/C work.
ak474u
May 4, 2015 11:15 PM
Aug 2, 2006 01:35 PM
scandalus
Jul 24, 2006 01:54 AM
abelh7
Jul 7, 2006 08:02 PM
accordn2me
May 25, 2005 04:00 PM
