AC Leak
Old Aug 14, 2010 | 07:03 PM
Kreativ3z's Avatar
Default AC Leak
Whats the best AC Leak sealer out there? Got a leak in my AC system but got no Idea where...
Another thing is, when I check the AC with a gauge it says it's full but No cold AC comes out so do I have a leak or what?
The Compressor works fine since I made a switch to turn it on...
Old Aug 14, 2010 | 07:34 PM
You should put your year/model/transmission in your signature, so we don't have to look at your previous posts to figure out what accord you own.
What kind of a/c gauge are you using to read the pressure?
Old Aug 14, 2010 | 07:41 PM
Kreativ3z's Avatar
Oh man sorry, Accord 1996 LX 2.2
Was using the one that comes with the r134 cans.
The AC was working fine for a while but the seemed to just stop working even with the Compressor on.
Should I just take it somewhere so they can check the high pressure one to? Really don't know much about the AC system...
Also when I try and release some freon from the low side only gas comes out but no freon, and before freon used to come out...
Old Aug 14, 2010 | 08:13 PM
Freon can be a gas or a liquid depending on the pressure.
To get an accurate idea of what is going on the a/c system, you need to put a manifold that will read the high and low side pressures.
I bought one for ~75 at one of the parts stores. I think it was made by interdynamics. FYI, some come with the hoses, some don't. You also want a R134a set, if you decide to go this route.
I am not a fan of bypassing anything on a car. Is the clutch plate engaged with the compressor pulley and spinning with it?
Johnene
Aug 24, 2010 06:59 AM
v-tec23
Aug 14, 2010 08:43 AM
EBK142
Jul 20, 2009 09:10 AM
xaznxeclipsex
Sep 28, 2007 02:05 PM
Sep 23, 2007 09:28 AM
