Sponsored by:
Sponsored by:
Accessory Power Socket failed - pin doesn't touch
Old 08-12-2006, 07:44 PM
dtc
Default Accessory Power Socket failed - pin doesn't touch
Hey folks,
I have a 2002 Accord, and I have the strangest problem - only some devices work when connected to the Accessory Power Socket (formerly known as the cig outlet).
It looks like the contact at the bottom of the outlet is stuck "down" and so that it only comes into contact with the devices that have a longer pin. Which... pretty much excludes most devices (gps, radar detector - only my inverter has a pin that's long enough)
Is this something that can be easily fixed or do i need to replace the entire socket?
Old 08-13-2006, 01:16 AM
Default RE: Accessory Power Socket failed - pin doesn't touch
ok this is a dumb one but here it goes.
did you try sticking something sharp like a pencil and try pushing the pin further back. It is spring loaded
so it mught actuality release on its way back.
JimRob
04-26-2023 05:39 PM
jdubicki
01-07-2019 10:55 PM
RandyJW
09-17-2011 09:58 AM
suna22
03-16-2010 04:57 PM
dm128956
05-09-2007 02:10 PM
Quick Reply: Accessory Power Socket failed - pin doesn't touch
