Accord 04 EX - Clock stuck at 00:00
Ok by downloading the software again you reset the system. At this point the only thing I can things of is disconnecting the positive and negative battery cables and touch them together for a few mins. Other than that maybe a newer navigation disc. I've never see where you could not adjust the time.
Hi all, so this issue manifested after getting a new battery installed in my Honda Accord '04 EX. (With the touchscreen navigation)
I have unlocked both the radio and the navigation respectively with each of their codes after the new battery. The clock above the dash is displaying an inaccurate time. Normally, I adjust the time using the touchscreen navigation in the settings, but it is locked to "00:00". It will not allow me to adjust hours or minutes, tried it with the automatic GPS setting on and off. (The map navigation and satellite radio are both working fine, so it doesn't seem to relate to the signal.)
To my knowledge, there is no other way to adjust or set the clock in the EX. Any ideas?
I have the exact same issue and dealership can't do anything.
Did you ever figure yours out? I've learned to live with mine, but would still like it fixed, especially if I ever go to resell
I read where someone said the Accord defaults to 1PM after disconnecting the battery, and attaching it on the minute is a way to workaround. If you try this out before me, let me know
Jason
bradn07
Jun 4, 2010 01:52 PM
