Accord 04 EX - Clock stuck at 00:00
Old Feb 28, 2021 | 07:29 PM
Seanjordan20's Avatar
Ok by downloading the software again you reset the system. At this point the only thing I can things of is disconnecting the positive and negative battery cables and touch them together for a few mins. Other than that maybe a newer navigation disc. I've never see where you could not adjust the time.
Old Apr 2, 2021 | 10:07 AM
Jason Brinkman's Avatar
Originally Posted by terryz99
Hi all, so this issue manifested after getting a new battery installed in my Honda Accord '04 EX. (With the touchscreen navigation)
I have unlocked both the radio and the navigation respectively with each of their codes after the new battery. The clock above the dash is displaying an inaccurate time. Normally, I adjust the time using the touchscreen navigation in the settings, but it is locked to "00:00". It will not allow me to adjust hours or minutes, tried it with the automatic GPS setting on and off. (The map navigation and satellite radio are both working fine, so it doesn't seem to relate to the signal.)
To my knowledge, there is no other way to adjust or set the clock in the EX. Any ideas?
I have the exact same issue and dealership can't do anything.
Old Aug 5, 2021 | 11:54 AM
terryz99's Avatar
Did you ever figure yours out? I've learned to live with mine, but would still like it fixed, especially if I ever go to resell
Old Aug 5, 2021 | 04:14 PM
Nope. Couldn't figure out how to fix it. Nobody has.
Old Sep 23, 2021 | 09:09 PM
terryz99's Avatar
I read where someone said the Accord defaults to 1PM after disconnecting the battery, and attaching it on the minute is a way to workaround. If you try this out before me, let me know
Old Sep 24, 2021 | 09:07 AM
Yes, that does work. I pulled the gnd and then reconnected a couple of minutes before 1. You will need to go through the log in process so you will need your radio codes. I entered the data and at 1 PM I hit the enter key and the time set at 1 PM. What I have noticed is the clock is running slower and slower so my time on the dash display is 10 minutes behind. I will have to redo it again to zero out the delay.
Jason
dsappy
Apr 4, 2011 08:43 PM
bradn07
Jun 4, 2010 01:52 PM
mesmerizer016
Dec 12, 2009 08:20 AM
timmy786
Apr 7, 2008 11:48 AM
old88dog
Jun 13, 2007 10:58 PM
