Accord 06 radio frequency all wrong
Old Dec 27, 2013 | 01:12 PM
Jeremy Chan's Avatar
Default Accord 06 radio frequency all wrong
Hi guys,
I have a problem with my accord radio set. The range of the FM radio frequencies are now haywired! They have a difference of "12" - if i like to tune to channel 98.0FM, it will be displayed as 86.0FM (98.0 - 12.0)!
Anybody knows how to reset this?
Thanks!
Old Dec 28, 2013 | 04:49 PM
RobinsonRicer's Avatar
Just a guess, I'm not an expert on this.
Busted radio?
Try disconnecting the battery.
Old Dec 29, 2013 | 12:14 PM
Here's another guess: Not in the USA?
USA FM radio frequencies are always odd-number for tenths of MHz. Like 98.5, 98.7, 98.9 MHz and you will not find a 98.4 or 98.6 MHz station.
I know that doesn't really answer your question, but the radios in different parts of the world are different. Keep that in mind when you try things that we might suggest.
Old Dec 29, 2013 | 04:19 PM
You can have the battery and charging system tested, as sometimes low voltage can cause weird electrical issues. In addition, try disconnecting the negative battery cable to see if it changes anything.
Otherwise, it sounds like a problem with the audio unit's internal PLL tuner or microprocessor if it wasn't doing that before.
Since you're not in the U.S., have you checked other digital tuners to see if maybe there's some change in broadcast frequencies for the area you're in?
RobinsonRicer
Jun 3, 2013 08:21 AM
Tony1M
May 2, 2013 05:25 PM
gino1962
Dec 13, 2011 03:37 PM
indy49
Dec 1, 2008 08:48 PM
alexh90
Feb 23, 2007 09:46 PM
