Accord 1989 doesnt start when hot
Old Sep 14, 2009 | 08:09 PM
rmoreno17
Unhappy Accord 1989 doesnt start when hot
Hey buddies, since a few weeks ago my car doesnt start when hot, it needs a little cooldown before start again. Somebody told me about the main relay and I exhange it and it doesnt work. I try starting it using a gas wetted cloth and it starts well. I want to test the resistor module that feed the injectors but I Dont have a clue about where to find it ir how it looks. Any advice about where to find it?
Accord LXi 1989
2.0 mfi
Old Sep 15, 2009 | 10:42 AM
Exclamation Hi New Member
This goes to the General Forum where you shall get help...I moved you to here...
Thank You for posting..
Old Sep 15, 2009 | 12:46 PM
Look on each injector's wiring plug. One wire on each, is all the same color (red/black?). THAT wire should have battery voltage when the key is turned ON (don't start the engine). That's a crude first check of injector circuits.
All my Hondas were more recent & didn't have resistor boxes, so I hope someone chimes in with more checks.
Old Sep 16, 2009 | 11:35 AM
hondadude's Avatar
I'd suggest you cut to the chase;
Use a long screw driver as a stethoscope and listen for the injectors CLICKING when he engine is being cranked.
Turn on the key, stand on your head behind the drivers seat, check for flash code from the ECU.
It might be worthwhile to check the temp sensor.
90snowman
Jan 27, 2024 10:26 AM
gasface11
Jul 11, 2012 12:33 PM
TronAE86
Mar 8, 2010 10:50 PM
scotthoward
Nov 19, 2008 05:41 PM
vindedreal
Nov 24, 2006 11:20 PM
