Accord 1996 : PCV Hose
Old Apr 7, 2014 | 08:29 PM
curvenut's Avatar
Default Accord 1996 : PCV Hose
Hi,
I just broke my PCV Hose when replacing my PCV valve.
I just check online and just the hose cost 36$$$
BULK HOSE, VACUUM (7.3X3000)-1996 Honda ACCORD SEDAN-95005-75003-10M
Where can I find and what king of hose can be used as a cheaper solution to replace the PCV hose ??
Thanks
Old Apr 7, 2014 | 08:43 PM
The reason the hose cost so much is because that is bulk hose; 3,000 mm or almost 10 feet.
Just bring the pcv valve to an auto parts store that sells bulk hose that they cut; so, they can match up a hose with an inside diameter close for the valve.
Old Apr 7, 2014 | 08:51 PM
If 7.3 is the inner diameter (ID) in mm, then a 9/32 ID vacuum hose should be the closest to match the metric. A hardware store would be a good place to start. Call your local chain auto parts store. Maybe chain stores like home depot.
If you just tore the original hose a bit, some electrical tape would be a temporary fix until you find a replacement.
Old Apr 7, 2014 | 09:09 PM
Autozone site show they have in stock for pick up in stores:
Armor Mark/9/32 in. vacuum hose - Sold by the foot for $1.19/ft.
Old Apr 7, 2014 | 09:29 PM
curvenut's Avatar
Thanks Red & PA !
I"ll check at the part store or hardware store ..
Old Apr 8, 2014 | 07:32 AM
At the hardware store you might have to be careful to get hose that can stand oil & heat without softening.
Old Aug 7, 2015 | 01:55 PM
jkowtko's Avatar
Almost A Senior Member
I really don't like the way the Gates hose looks ... it's also a lot harder to squeeze.
If anyone wants to go in on a group purchase of some bulk 95005-75003-10M, I'll pitch in 10 bucks for my foot's worth.
Thanks. John
jkowtko
Jun 9, 2015 12:52 AM
cukaracha
Jul 16, 2014 06:59 PM
jamesejam
Sep 21, 2009 02:37 PM
stevemacleodns
May 5, 2009 11:49 AM
WhyNotFab
Jan 17, 2007 09:45 PM
