Clean 04 Accord PCV valve / hose
Old May 5, 2009 | 07:31 AM
stevemacleodns's Avatar
Default Clean 04 Accord PCV valve / hose
Hi All
I am noticing a fair amount of black soot in the end of the muffler, could be running rich or blowing oil thru maybe. My motor (EX-L 2.4L automatic) has 167,000 kms (equal to 100,000 miles) and so I am looking at the PCV valve. If I pinch the hose the idle does falter so I can believe it is working to some degree but wondered if a cleaning would be a good idea. I can obviously replace it but at $40 Cdn it might be worth getting some gas on my hands too. I have two questions then.
1) When I thread the pcv valve out of it's spot on the engine, does that allow coolant to come out.
2) Can these valves be cleaned successfully?
Thanks
Steve
Old May 5, 2009 | 09:23 AM
finch13's Avatar
Are you sure it's the PCV valve?
The PCV should be located on the valve cover with a hose running to the intake manifold. A new PCV valve is less than USD$5 at the parts store, the hose should be fine.
Old May 5, 2009 | 09:32 AM
hondadude's Avatar
There is no coolant in the PCV line, [Positve Crankcase Ventilation] oil vapor is all that goes thru it.
When you pinch off the vent line you should hear the valve lightly click.
There is no hazard to cleaning the valve out with carb cleaner.
Old May 5, 2009 | 11:49 AM
On the 7th-gen, the PCV valve screws into the block, not the valve cover. The hole opens up into the crankcase, into an oily air space. Not into the water jacket. You won't have stuff flowing out when you unscrew it.
curvenut
Aug 7, 2015 01:55 PM
jkowtko
Jun 9, 2015 12:52 AM
cukaracha
Jul 16, 2014 06:59 PM
the cyclops
Jul 24, 2011 03:05 PM
WhyNotFab
Jan 17, 2007 09:45 PM
