accord 2000 2.0L coolant drain
Old Mar 21, 2018 | 05:55 PM
Eran Teitelbaum's Avatar
Default accord 2000 2.0L coolant drain
hello
i was trying to drain the coolant from the cylinder block but couldn't find the bolt.
it's not where the owners book shows:
the only bolt on the rear side is close to the timing gear side, but no coolant came from there, only a little bit of engine oil:
from what the book shows i'd expect the bolt to be where the red arrow points to, but there's nothing there. it's a threaded hole, but it's blocked. could it be the plug under the oil filter?
Old Mar 22, 2018 | 03:10 PM
The Toecutter's Avatar
Originally Posted by Eran Teitelbaum
hello
That bolt isn't it. That bolt is basically a plug to access the balance shaft pin hole (to lock the balance shaft for belt replacement). I think you either need to look further up (you can just make out the coolant tube in the top of your pic), or you need to look on the front side of the engine.
Old Mar 22, 2018 | 07:50 PM
Are you just trying to change the coolant?
Old Mar 22, 2018 | 08:33 PM
yes i am.
Old Mar 22, 2018 | 08:36 PM
The engine block coolant drain bolt is to the left of the oil filter.
See the illustration as part of this engine block heater install instructions.
File Type: pdf
Old Mar 22, 2018 | 08:56 PM
Just make it simple. Drain the coolant from the radiator and refill with new coolant. This will dilute any old coolant in the system.
Old Mar 22, 2018 | 09:10 PM
thanks for the help, i'll crawl again under the car to look for it.
i prefer to drain it completely.
Old Mar 29, 2018 | 09:11 PM
found it!
qw
anupm12
Sep 15, 2014 11:21 AM
slickgeek
Jul 20, 2014 01:41 PM
jon02accord
Mar 26, 2008 10:54 AM
hondafreak2
Dec 15, 2006 06:43 PM
Ronin_301
Jul 5, 2006 12:54 AM
