Accord 2007 horn replacement
How to replace the horn of accord 2007 , some time its started working and sometime stop, please let me know what is the exact problem. If there is any video or pictures it will really help.
Thanks & regards,
farhan
Thanks & regards,
farhan
In the common DIY thread on top of the gen tech help forum, there is a link to online shop manuals. There is one for the 03-07 Accords. I think that you should verify that you are getting voltage to the horn when the horn button is pressed before blindly replacing the horn itself.
I would unplug the horn electrical connector and test for voltage. If you have 12V, then replace the actual horn.
If you don't have 12V, then I would move to the relay and test. Finally, I would test the horn button on your steering wheel.
also do you know where the relay is located ?
sagdast
Dec 31, 2010 11:41 PM
lalblue
Nov 25, 2010 08:06 PM
